Hi there,
I have been using your amazing theme for a while but there is something I am always struggling with.
How can I display the thumbnail of a specific article with a clickable text underneath?
This is a perfect example of what I want to achieve: https://tinyurl.com/4e6jxxze
I don’t want to filter by last post or so, I want to choose the articles I want to display one by one. I will have 1 by column.
And I also want the text underneath to change color when I mouse over the image or the text itself.
Thank you very much in advance for your insights.
Cheers,
Adrien
A workaround there could be to use a Post ID filter from the tab Filter from the element’s settings and the articles will be always the same there -> https://i.imgur.com/KuicQ9U.jpg
Documentation here: https://forum.tagdiv.com/flex-block-settings-guide/
This is exactly what I was looking for, thank you very much Anamaria!
