Hello, well as I´ was, take a look in the source code of my website, i found the following line; <body class=”home page page-id-25117 page-template-default custom-background amigo-de-cristo wpb-js-composer js-comp-ver-4.7.4 vc_responsive td-full-layout” itemscope=”itemscope” itemtype=”http://schema.org/WebPage”>, in red into the source code, some one could help, in sort this out?
I can’t see anything to sort out. That is the code for the body tag and the shema information for it. There is no error. It;s the same on our end as well: http://screencast.com/t/tPNEHMMTih9
There is nothing to fix.
Hi, tanks for the reply, but any way this line in Firefox browser appears in red collor, and close head tag has the same warning, https://www.dropbox.com/s/zjzqbhxvjha8a5s/error%20in%20tag.JPG, I´ know thats is causing any harm but, as I note, this appear only in the source code on this one, after I done the update for the last version.
Unfortunately there is nothing we can do about it. I’m not sure what firefox sees in the page source but test out our demo and see if the code is red here as well: http://demo.tagdiv.com/newspaper/ and if it is, then simply ignore it as that is an essential part of the code and cannot be changed.
Hi, Bogdan B. tanks for the clear reply, I´ve done the test and is fine..!
