how to fix CLS and LCP issues on Newspaper theme?
I tried finding out in all your documents, but could not find.
Since the last Newspaper theme we are facing LCP and CLS issues on both desktop and mobile newspaper sites.
And all have to do with tagdiv and newspaper.
For example CLS –
Layout shift score: 0.1865
div.tdc_zone.tdi_67.wpb_row.td-pb-row
div.vc_column_inner.tdi_31.wpb_column.vc_column_container.tdc-inner-column.td-pb-span8
div.td_block_wrap.td_flex_block_4.tdi_82.td_with_ajax_pagination.td-pb-border-top.td_block_template_1.td_flex_block
div.vc_column_inner.tdi_36.wpb_column.vc_column_container.tdc-inner-column.td-pb-span12
div#tdi_37.td_block_inner.td-fix-index
and
Layout shift score: 0.0596
div.td-block.td-a-rec.td-a-rec-id-custom-spot.tdi_32.td_block_template_1
these all shifting on desktop, which is very high.
Similar problems with LCP too.
How to solve?
website: GadgetBridge.com
  • This topic was modified 7 months by SP1.
I just checked your website using https://pagespeed.web.dev/ and on the desktop version, everything is on green https://prnt.sc/bHSSt9ZvxV2A on mobile, there indeed is a situation with the LCP but CLS is 0 https://prnt.sc/pQ9Pqd4C4n0F on the homepage but checking on an article, the cls and lcp are on green on both mobile and desktop – https://prnt.sc/WxF1R04-ffEL – https://prnt.sc/kCygD_uSxhHY
