How to Fix Overlay Header on Single Post view
How to fix overlayed header on single post. Not only on single post but also in category list, page, and other. But in home page view it seem okay. Here as I attach screenshot. Thanks.
screenshoot with overlay header on single post
not only on single post but also in category list, page, and other
Hello !
That is the sticky header. It can be disabled as you can see in our video here: https://www.youtube.com/watch?v=HXQQygkCCJo&t=1s
I try to on-off sticky header, but it still not work.
But it worked when I change header for different view, like single post or category to non-overlay header template. It solved now for the overlay-header template.
Hi bappedagarutkab,
I think that the problem is that you have set an overlay header as global in theme panel -> https://i.imgur.com/aL31ECR.png this will apply on entire website.
What you can do to this this, is to set a different cloud header from tagDiv Cloud Library as global, then edit the homepage with tagDiv Composer -> https://i.imgur.com/383IVrI.png select the header manager and set that overlay header -> https://i.imgur.com/4FVw8Xg.jpg
Or if you want to set the overlay header to a fix one, edit a page/category/single post template with tagDiv Composer -> https://i.imgur.com/DJ7oULy.png click on logo, then one header menu -> https://i.imgur.com/safAshz.png then set to display the menu as default -> https://i.imgur.com/Smuj33u.png -> https://i.imgur.com/6y3gete.jpg
Hope this will help you!
