How to Fix Posts Not Showing up in Categories on Newspaper WordPress Themes
My latest post is not showing up in the post category on the Newspaper theme. Is there a way to fix this? Can you please provide a detailed explanation on how to resolve this issue?
I think that I know what the problem is, please edit the cloud template with tagDiv Composer -> https://i.imgur.com/j8YvKks.png click on the block and remove the offset -> https://i.imgur.com/dJ0iFQu.png let that field empty.
If you don’t mean this please give me more details, and screenshots.
