how to fix the posts or images of the header grid or block
grid
purchase code:
https://thailaw.info
It’s always updated with new posts, but I would like to fix this header part.
  • This topic was modified 8 years by Numaphon. Reason: giving you more explanation for my requirement
Unfortunately the big grid as any other block is a whole unit. it cannot be controlled separately and make a post sticky and have the rest be dynamic. In order to do this you will need 2 separate blocks. You cannot have 2 different filtering options in the same block .
I don’t need filtering
Just only need the images to be shown on the top
Please provide an example of how your images show up. I cannot see any grid on your site.
Top Images
Help me please, Bogdan.
Thanks so much!
The “Trending now” title can be customized in the Theme panel->Translations section
https://www.screencast.com/t/WHHl9UJVPyS
Big grids and blocks will display n posts or pages, please see this tutorial
https://forum.tagdiv.com/block-settings-guide/
So you can display the pages you want in the big grid, by setting the post type to page
https://www.screencast.com/t/3jGWGT0X
To control the exact order of the pages or posts in the grid you would have to enter the IDs manually in the ID filter
https://www.screencast.com/t/WNGfSi48J
