Hi Support team,
I am displaying Weather info using Newspaper theme feature (Enabling SHOW WEATHER) and in Location field I don’t want to give static location or postcode of the city to show weather rather than want to pick and display weather info of the user current location.
Is there any feature or solution for displaying weather depending upon user different location.
Would be really appreciate for any help!
Kind Regards
John
The theme already provides this functionality in the weather widget Please check this option: https://www.screencast.com/t/RwPnHyJR
A user can click that button and a prompt from the browser will pop-up to ask for the consent of the user to use the location to provide the local weather for the user location. This cannot be done automatically as you need a user’s accept to access his/her location
