I’m using menu with td composer page content for the main navigation menu submenus to create a sort of mega menu. This works nicely on desktop, but it does not display on mobile, which is understandable. How can I show a simple submenu list of links on mobile instead of the set page content?
If I add submenu items to the wp menu it almost works, but it outputs 1 item on the desktop version along with the embedded page and messes that mega menu up.
I see we can select a different menu in the header composer for the Mobile view.
What’s the best way to handle this? Create & manage 2 versions of the menu, or is there a way handle this with one menu?
Hello !
If you are using the mobile theme plugin you are able to create another menu specially for the mobile viewport as you can see here: https://www.screencast.com/t/FmU7mtjhI
Ok, Thanks. I did see that and what I set up. I guess I was hoping there was another way so we didn’t have to manage 2 menus.
