How to inject a custom filter on block using function file
Hello everyone, How to inject a custom php filter on custom block using function file or td api plugin?
If you want to develop this functionality, you need to do it yourself through the code and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
You can check this documentation
-> https://developer.wordpress.org/reference/functions/add_filter/
-> https://codex.wordpress.org/Plugin_API
Also if you have the last version of theme ( v9.7 ) the API plugin will not work anymore.
