Hello. Thx for great theme!
Can you tell me which file should I edit to put custom code above breadcrumb in article view?
It is the same place where “header ad” is showing. However I need to put custom ad code only on specific articles, not globally, so I can’t use “theme panel ads”.
Thank you for help.
Peter
If you want to add that custom code in that section, you will need to edit the header style used by you and add the shortcode in that section. Please note that is not a simple task which required to affect the theme core file, like this -> https://www.screencast.com/t/55NVEkt0fQV If you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
