How to insert 'read more' in articles
Hello !
Unfortunately it is not possible with the basic functions from NewsPaper or WordPress. But as i’ve searched a bit you can achieve this with a plugin. We haven’t tested any plugin so we cannot recommend but as long as you make a backup you can feel free to test plugins. This one looks promising but you will have to test it:
-> https://wordpress.org/plugins/read-more-login/
I’ve made some quick tests with this plugin and it’s pretty simple to work with but i can see it has a bug with the smart sidebar, so if you don’t want the smart sidebar i think this will be great.
Let me know how this works !
Thanks man! Your are the best
