How to keep head menu showing when I scroll screen?
Hello! May I know how to keep head menu showing when I scroll screen on PC and mobile?
Thank you in advance!
You can set the main menu to be a sticky menu from Theme Panel-> Header -> Main Menu => https://www.screencast.com/t/ShRFfKhm81,
or if you have a Pro Prebuilt Website you can set with tagDiv Composer in Manager, you can enable the sticky menu on desktop and mobile = > https://www.screencast.com/t/YTp5YZqel.
Hope this helps you!
