How to make anchors going to parts of a page
I would like to make anchors like a button that when you click on it that you go to a certain part of your page.
To create anchor links on pages, you need to use the tagDiv Composer and set to a row an id, then set the link to that page plus the id like this ->
– https://www.screencast.com/t/dzsIlRQFx
– https://www.screencast.com/t/7yBu0LhdYDrO
Also there is another solution, instead of setting id you can set a class for row and set in the menu a code like this: https://pastebin.com/WFY1mBNy just replace your-class with the class you set.
I hope this will help you!
