Hello
Currently my site has over 100 internal links on front page alone because all the images are also being clunted as links (this is very bad for seo causing page authority to bleed interally causing a lower global rank
I want to (should be able to) do exactly as this sample. This site sample only the titles are clickable. This is very verey good because its not causing hudrends of un nessasry internal links. You will see. You can’t click on the image, there is no link. Only the title is a link. (this is very good for seo)
Please tell me how to acheive this basic very good seo optimisation factor with newspaper. If you dont have this fuction (dont see why you dont) please add it to your next uodate because this is a massive help for SEO and not causing bad seo problem.
I hope this can somehow be done currently. Can you?
I just checked the mentioned website and the modules structure is different. The background image is used and on it are set individual links, in our theme the background image is inside the title link.
But what you can do is to use this option -> https://i.imgur.com/TJ8gZ4d.png this should help you with the links.
