How to make theme auto fit in high resolution screen ( for example 19 inch + )
How to make theme auto fit in high resolution screen ( for example 19 inch + )?
Specially for desktop.
Follow up on this.
Unfortunately, the theme does not have any such an option for that because the full-width functionality is not available for Newsmag, sorry!
Is there an alternative way to do it on CSS?
It is not a recommended way to do this because you can easily break the layout of the theme, sorry! If you want a full-width layout, we recommend buying the Newspaper theme which has included this functionality.
