how to modify Block 1 and Block 2 menus?
It’s not possible to do it through WPBakery
I tried widgets, menus, theme panel…
Thanks,
Giancarlo
Are you referring to the ajax menu? – http://prntscr.com/moinfv
If so what exactly do you want to modify about it? If that is not what you mean, some more details would helpful, screenshots if possible.
I want to modify the menu itself. I want to cut out unwanted items.
All you need to do is to set the category filter like this -> https://www.screencast.com/t/orqQo2aP8KVn will be filter all posts and show only posts that have that category and if you set filter type and show the following ids -> https://www.screencast.com/t/coiPoPjQxBj then the filter will look like this -> https://www.screencast.com/t/cNk2eROftRl if you click on all will be show the category filter ( in this example New Look, all post that have that category ), if you click on a category id will be show all post that have that category, not all post from the category filter that have that category. -> https://www.screencast.com/t/Osxp0xRsL4HM
