In the Theme Panel, in the Post settings, I didn’t find a setting for changing the color of links to other web pages. Could you please tell me where I can find the relevant setting.
Another thing related to weblinks.
In the previous version of the Newspaper theme (I’m using Newspaper 6 now), I did not have to tick “Open link in new tab” every time I added a weblink. My setting was “remembered” once I had made it.
It gets tiring to have to open the link settings dialog every time to just tick the “Open link in new tab” setting.
This is a setting that we use for all our weblinks in posts. Isn’t there any way to make the setting permanent (until changed)?
Thanks in advance.
This topic was modified 9 years by
Vesa.
The color of all the links are handled by the theme accent color from the theme panel: http://screencast.com/t/uaRyPyZVJt
Unfortunately for the links there is no such option. You cna maybe try a plugin such as https://wordpress.org/plugins/open-external-links-in-a-new-window/ but it;s not tested so i cannot guarantee it;s functionality
Ok – thanks for the answer and suggestion. The ability to separately modify link color could be a future development idea.
But what about the need to check the “Open link in new tab” option separately for each and every link?
As I mentioned, this appears to be a setback from the previous version. Could it even be a bug?
It is not a bug as if it was it would have been resolved by now. It is just the way wordpress handles links. Try to switch to a wp default theme like twenty sixteen and see if the open in anew tab remains saved. It is a wordpress setting not a theme setting.
