When “SHOW RELATED ARTICLE” option is enabled in Newspaper “POST SETTINGS”, by default there are posts from
– RELATED ARTICLES (posts from the same cathegory)
and
– MORE FROM THE SAME AUTHOR (posts added by the same author)
displayed at hte bottom of an article.
How to modify/choose this option so that other types / cathegories / tags / groups of atticles are displayed in this box with so called RELATED ARTICLES?
Eg. in case somebody would like to display there RELATER ARTICLES from eg. CATHEGORY_A and CATHEGORY_B or other groups of posts (not as in the default setting, posts of the same author and posts from the same cathegory as the “main” article where the box is displayed)?
Regards,
I can not access your screenshots.
For example, add a flex block in a post go to the filter tab of the element’s settings and from the dropdown category filter you can choose between: Single – More from author, Single – Related by category, Single – Related from tags.
So, for example Related from tags is displaying articles/posts which have the same tags as the article you are currently viewing. Also, you can set Related and sort it as Random for example.
Please note that you should place that flex block in a post template to have effect.
If you do not mean this, then please provide more information about your issue and your website link.
I’ve double checked: all the links to screenshots are accessible without any problems (similarly to the ones the were uploaded earlier).
The issue is not related to FlexBox so this answer doesn’t help.
Again: when enabling ““SHOW RELATED ARTICLE” option, by default there are posts from:
and
displayed at hte bottom of an articles / posts .
How to modify/choose this option so that it doesn’t show RELATED ARTICLES and MORE FROM THE SAME AUTHOR posts
but
Eg. in case somebody would like to display for the RELATER ARTICLES eg. articles CATHEGORY_A and CATHEGORY_B or other groups of posts (not posts of the same author and posts from the same cathegory as in default settings) how to configure that?
Regards,
