I used plugin Automatically Paginate Posts for that in which i can able to add pagination automatically, but the pagination show after comments (i used facebook plugin).
https://www.screencast.com/t/qF8zqSn2YAoH
Is it possible to add pagination just after post?
this is the sample page
http://www.kbknews.id/2018/02/19/meski-sudah-ada-shelter-ternyata-belum-semua-warga-kampung-akuarium-bahagia/
If the Facebook comments were removed then the pagination would display below the article, as it should. But it is displayed below, that could only be modified if the plugins have options where to appear. Check each plugin settings, if there are none in the matter, then they are both supposed to appear below the post as they are now. They cannot be controlled through the theme.
