I need to organize homepage into sections (it’s not enough for me organize only for categories).
I do not want to use a second category for it. It ‘will be a configuration to help me to organize content into sections and not for the respective categories?
For example …. I configure a box in the home with a certain layout and I want in that box there is always a content of a particular type (or a content that i choose but not by category…..the classical example of featured post).
I think is improper use other categories to create this parallel organization .
I thought that I can use the tags (I saw that in filters of the boxes of this template can only filter or by category or tags, and not for a custom taxonomy) in the sense that I would use the tags only to define the various sections of the home but then lose the proper use of tags that I should replace them with custom taxonomy.
If anyone can help me clarify the issue I would be very grateful.
The theme doesn’t have such an option and I suggest to find a plugin that may help you. I don’t know if this can help, but the on the block settings you can set the category and also the tag in the same time – http://screencast.com/t/o3gJ5oneip
If you need another implementation I suggest to get someone to help you with this, as we cannot provide custom work at this time or like I said above try to find a plugin.
