When I add a link to a related internal article, the card sometimes appears with the small image on the left, and sometimes with the image centered and large. I like much better the design with the small image on the left, because it avoids the reader having to scroll too much to continue reading the article. I would like to know how to choose when each image is displayed. Thank you.
If you add the link like this-> https://i.imgur.com/e0SAKbm.png , then you can’t edit the design.
