How to place Ads between posts or after 3rd posting or after infinite load posting
Did you have tried to use the Article Inline Ad functionality from here -> https://www.screencast.com/t/MtRMnQk2lgRI
Hope this helps!
thank you for your reply.
but sorry, that’s not what I meant.
My point is how to place ads after the 3rd post from block 11 on the front page
Sorry about that! If you want to add some Ads after some blocks, on the page, you need to use the Ad Box element, added it with TD Composer. As a hint, you can follow the next steps from here -> https://www.screencast.com/t/7LRCMKO5K
Hope this helps!
