Hi!
I’m sorry for asking such basic question, how can I reproduce article meta info row of prebuilt template GOURMET PRO?
Detail;
In the Single Template of Cloud Template for GOURMET PRO, there’s a row which shows meta info such as author name, date, page views, number of comments above article section.
When I try to reproduce same row via tagDiv composer, I couldn’t done it properly.
For example, please check the image I attached. I drag and drop Single Post Date element to right next of number of comments element (Where blue arrow indicates). But it doesn’t settle on right place and it wants to settle on light-green highlighted area and then it’ll be inserted on the place underneath ‘Sample Post Subtitle!’.
How can I place elements side by side to achieve creating the row like the one on original template?
https://drive.google.com/file/d/1NZpGySQeYC088Lbt3UMwWw7OhFgWrjjL/view?usp=sharing
To achieve that you need to use a row, divide the row and set the elements to be inline, like in this video => https://we.tl/t-s7qlgEZd10
Hope this helps you!
