How to promote authors of a multi author web site?
I used a Dev site to upgrade to the newest Newspaper theme.
https://dev.debatt1.no/ (The site is in Norwegian)
The client wants to promote authors.
Going to the post. An example. https://dev.debatt1.no/na-ma-folk-skjerpe-seg/
On the right side as a sidebar widget we have Search and Recent Posts (which would be good to translate).
It would be great with an option to add a More from Author widget to the sidebar here. Promoting the author of the post that has been selected. Identical to the More from Author tab further down on the page beside the Related articles.
At the bottom is the Related Articles (RELATERTE ARTIKLER) and the More from Author (MER FRA FORFATTER).
How would we start with the More from Author initially/by default selected?
Or perhaps even how to remove the Related Articles and just keeping the More from Author tab?
Hello !
Those can be translated from Theme Panel – Translations. Also we recommend you to use Cloud library templates in order to have the ability to customize your templates using tagDiv COmposer and edit your sidebar as you can see here: https://www.youtube.com/watch?v=fa7GenCHcBU
