Sorry but our theme does not have this option. It will have to be made custom by altering the theme code. You have to manually add the nofollow in the code for each of the mentioned elements.
comments date and time: https://www.screencast.com/t/jfDWUj5NI
tags: https://www.screencast.com/t/Jb90lmmmlV
author box: https://www.screencast.com/t/zHEEjTqE89Z
Adding nofollow is not hard to do. Here is an example on how a link receives nofollow.
https://support.google.com/webmasters/answer/96569?hl=en
I have pointed out the code where to add it, I cannot do it for you.
Here is an example of how to do it: https://www.screencast.com/t/K8hxerD2C
It has to be added after the href attribute. Right after the colosing href quotation marks
I hope this helps.
i tried add this code for comments and date and doesnt works https://www.screencast.com/t/K8hxerD2C . Date on comment are follow
The nofollow always comes after the closing ” of the href as I have mentioned above: https://www.screencast.com/t/VG42fNkEe4ue
Then it seems you will require help from someone code savvy as I have already provided instructions on how to do it. If you do not have the proper skills to make the implementation needed you should hire a freelancer to hello out with the code. You can hire a freelancer from sites lie studio.envato.com
You will have to search for an online solution for that like for example: http://www.wpbeginner.com/wp-tutorials/how-to-optimize-your-wordpress-robots-txt-for-seo/
Unfortunately adding nofollow to parts of the theme represents customization and is not covered by the theme support.
The method I posted is the correct one. I have just tested this again and it works as expected:
https://www.screencast.com/t/08tzWfXK0Ph
The same method applies to the a tags. The search links can be found here: https://www.screencast.com/t/IxHjOYmaP
