How to put Google Adsense ads inside newspaper theme flex box or posts loop?
Please let me know if your code needs to be added between the head tags.
Also, you can add your code in the tab ads for posts loop -> https://i.imgur.com/JXi8JEz.png For Flex block, only if you have posts with featured video -> https://i.imgur.com/ov9YJwo.png
Thank you so much. i found it “posts loop ads location”.
How to put Google Adsense ads inside newspaper theme flex box?
https://ibb.co/6Z4xzLx
For Flex Block, you can add only posts which has a featured video set https://i.imgur.com/mmo8UBS.png
