How to reduce Column Width while using TagDiv Composer
This must be very easy to do but I am not able to figure it out, please help.
I am trying to create an empty page with composer and want to reduce width as in this image https://d.pr/free/i/X2p9pl
I am using pagebuilder + empty page template for creating the new page.
Thanks a lot
You can split the row in columns, stretch the row to predefined widths or full width, but not actually reduce a row width.
What exactly are you trying to achieve? If you want a smaller width, split the row and use only the columns you want. Example
– https://www.screencast.com/t/XItCU9C3
Thanks Simion,
I want the background of the page to be let’s say red color. so when I am splitting the rows then I am getting the white background for the unused columns. I want to create something like that http://www.bestgroomspeeches.com where the width is about 800-900px ( just guess).
I want a big white box of width 900-1000 and then I will put raw HTML in it.
THanks
b
Can anyone help? is it possible to do in this plugin or should I consider something else?
banana
@Simion C.
Can you please help.
Maybe something like this. Use the row layout I mentioned previously. Set a background color of your choosing for the row and stretch it
– https://www.screencast.com/t/K8rfiT6BwF9o
– https://www.screencast.com/t/Oq82diGbvK
Set a background color for the middle column
– https://www.screencast.com/t/lyuJQ75JeP1Z
Then enter your content in a text element or what you want to use there. The result would be similar to that example you provided
– https://www.screencast.com/t/TmXJy5jKkNof
Thanks a lot @Simion
I am almost there. I was able to manage do most of the things.
I want to increase the width of the middle column where I am pasting all my text like in your example here https://www.screencast.com/t/TmXJy5jKkNof
when I am changing the width on the column in properties its not coming properly in all the devices plus it’s moving towards one side of the page.
Is there anyway to fix it.
b
You could use the stretch row and content option instead, that will increase the column width
– http://prntscr.com/k1lpkz
If that is then too wide, you could reduce it by setting left and right padding for the text element
– http://prntscr.com/k1lvmd
Other than that I can’t think of anything else at the moment.
All the theme rows, columns and most elements can be hidden per device
– https://www.screencast.com/t/4bQTLFrzcRt7
– https://www.screencast.com/t/KnaMUficAmHx
So you could hide this row on mobile, and display a different or the same but with different settings for mobile.
Thank you very much. Really appreciate your help @simion
