Hello hkhasib,
First of all, please try to disable all your untested plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme and rule out any conflicting plugins. As a quick solution, you should use the code below and place it in Theme panel->Custom CSS area.
@media (max-width: 767px){
.td-container {
padding-left: 0!important;
padding-right: 0!important;
The result you should see here -> http://screencast.com/t/M1xvtqGqUe2N
Thaks for your understanding!
