How to Remove Author Box From Mobile Theme and AMP Post
Hey
I want to remove the author box from my website (infotonline.com) now. I got the option to remove Author Box from Desktop theme using Tagdiv Composer. But I haven’t got the option to remove author box from single posts.
You can open any posts of website, you’ll find a large author box after the article. So, how can I remove this box from my website in AMP theme as well as Mobile Theme without using TagDiv Standard Pack. We haven’t installed TagDiv Composer so suggest other way to remove this box.
I have attached the image of Mobile Author Box. https://ibb.co/mt3nyxT
Thanks !
Hello !
As you can see here you can hide elements on different viewports using taDiv Composer: https://www.screencast.com/t/ejkpWtgRs
Hi !
I have applied these settings with TagDiv composer but issue is still there. Author Box is not hidden in Mobile Theme and AMP even after choosing Hidden in CSS as it is can be seen in the image.
Suggest some other options to hide Author Box in Mobile Theme and AMP.
Thanks !
Hello !
We have reviewed your website and the author seems to be gone.
Please check and let us know !
