How to remove 'blue box' around audio player?
I have added a Gutenberg block ‘audio player’ in a draft post. When I click to play it in the TagDiv template preview window a ‘blue box’ appears around the player.
Is there a way to remove this blue box?
Hello !
Please provide a link to your page so I can inspect the issue and give a proper solution.
Hi Vlad,
The page is not live. How do I provide a link to a draft preview page?
Hello !
You will have to make the page live and only after that.
I’m not sure if this screenshot will work, but if it does, this shows the blue box around the ‘audio player’ mentioned above:
https://snag.gy/7rtTdA.jpg
Please let me know if you access the screenshot.
Hello !
Please insert it into a page and then give the link to us and we will fix it. I cannot tell where that issue comes from.
Hi Vlad,
I am still developing the blog so nothing is live.
I am not sure how to provide a private link in the draft post/page?
If I em right that “blue box” show only when you hover the audio payer and the focus is st on that audio player.
Let me know if is that, or how/when this is appearing on the audio player.
