Aug 10, 2020 at 3:39 pm
Hello, i do not want to display comment number on the comment section, is there css code wich can hide it?
Here is picture: https://prnt.sc/tx54nh
thanks
Aug 12, 2020 at 8:25 am
Hello !
Please use this css code: .tdb_single_comments_count {
display: none;
The code must be inserted here: https://www.screencast.com/t/J1Nxw5s5
Aug 13, 2020 at 8:56 am
Hello !
As you can see here: https://www.screencast.com/t/aqxI311Hf9G The code works on our side. Please make sure that you have inserted it correctly and clear your cache.
Aug 17, 2020 at 8:24 am
Hello !
This is how your comment section looks right now: https://www.screencast.com/t/M1uLycGzk Also from what I can see your comment section comes from an external plugin, therefore this modification is not covered by the support team.
