How to remove post read counter from Posts in Newspaper theme
How do I remove post-read counters from all my Posts in the Newspaper theme?
null
Please provide more information, screenshots and your website link in order to help you.
Hi Bettina,
Please find attached the screenshot.
Website: thepackman.in
null
If you a Single Post Template from Cloud Library, then you need to edit the post with tagDiv Composer => https://www.screencast.com/t/jHatJGC1qRf, select the Single Post Views => https://www.screencast.com/t/NhUGCRfI and with right-click, you can delete it.
If you have a standard template, then you can disable the post views from Theme Panel -> Post Settings -> Post and Custom Post Types => https://www.screencast.com/t/LAv90B5eZ
