how to remove post views and comment count from posts , theme option don’t work i try many times but the theme option don’t work.
please help me to fix this issue
thanks
Hi doradagostino,
I think that you are referring to these elements -> https://i.imgur.com/DKXTTQn.png if yes, then you need to check if you are using a PRO demo or a single post template, these are not affected by theme panel settings and need to be edited using tagDiv Composer -> https://i.imgur.com/nbRdwwl.png use the right click on elements that you want to remove – https://i.imgur.com/M4qWIaf.png
Hope this will help you!
