How to remove sidebar from the posts and custom posts
Hi, how to remove this “sidebar” Sidebar
  • This topic was modified 7 years by pbc.
With a sidebar (left/right) – https://www.screencast.com/t/ZVohYvLB
The post content space is exactly as it is the published post, so how you see it in the backend will be the final look.
Without a sidebar – https://www.screencast.com/t/hyY9IskV8
The post content in the backend will be the full width of the theme.
These would be useful, so you can see how the post will look eventually. If you want to remove that delimitation you will have to remove the code from the theme. There are a few topics about it
– https://forum.tagdiv.com/topic/editor-and-sidebar-line/
Got it, thanks
