Hello !
1. If the theme panel does not work you will have to edit your post template using tagDiv Composer as you can see here: https://www.screencast.com/t/CuSr76qDJ0jt ; https://www.screencast.com/t/0zlCrJYKbDk
2. Whatsapp will only be available on mobile devices.
