Hello lijojohnsonwk,
There is an option for it in Theme panel, like this -> https://www.screencast.com/t/0MVxsa6i -> https://www.screencast.com/t/jdcWjdCO
I just wanted to delete this box from comment section ! https://ibb.co/fjWs0F
If you want to remove the WEBSITE field from the comments section for each post when you are not logged in, you have to comment out/remove a snippet of the code from comments.php core file, like this -> http://screencast.com/t/Gowfsn12M9sx and the result you should see here -> http://screencast.com/t/BnQliVlXepr
Thank you for the message!
