How to replace comment on post by facebook comment ?
Hello murakami9
If you want to replace standard comments with the Facebook comments, you have to use the shortcodes provided by the plugin: http://screencast.com/t/t6De3HwW and replace the standard comments from the theme files in every template. http://screencast.com/t/wNkcby3T05.
I hope this helps.
How to know what single template i use ?
i follow this method but post page was blank
Hello murakami9.
Please replace the lines I have marked in this image from ‘single.php’: http://screencast.com/t/wNkcby3T05 with this code:
echo do_shortcode('[fbcomments]');
Make sure to uncheck the post comments in the plugin or they will be doubled
result: http://screencast.com/t/rDCliXPlGO
This will change the default comments to Facebook ones but only on posts with the default template selected.
If you use another post template, you will need to modify the other files with the number corresponding to the template used: http://screencast.com/t/r7xs3oegMm2.
I hope this will bring light to the subject
Nice!!! Thank you Bigdan
thanks for this! just want we need
