Hello murakami9,
Our theme uses the WordPress standard comments module just styled differently. You can use a plugin like ‘Facebook comments’ https://developers.facebook.com/docs/plugins/comments , which adds comment boxes but you will need to remove the default ones from the theme files. Replace theme’s default comments for each post template – http://screencast.com/t/wNkcby3T05.
You can read more about it in this topic here: https://forum.tagdiv.com/topic/how-to-install-new-official-facebook-comment-update/.
If you do not want to modify the theme files there are other plugins that can replace the comments without you modifying the theme files, but we have not tested them and cannot make a recommendation.
