How can I restore the fonts of the default demo? I did something silly in the theme panel and now I can’t figure out the exact fonts that your default demo uses. I don’t seem to have an option to restore them, either. I can’t provide you with a link, because I am using a local installation. I have v.6.
Sorry for the inconvenience.
Do you have demo installed? You can uninstall it and install it again. Not sure what the issue is, but you can also change all fonts on default manually – http://screencast.com/t/hE1ZPEE5yyp7
Thank you for your reply. That’s the thing, I wanted the fonts the same way they came in the demo — before I changed them by mistake. If I recall correctly, I saw the Roboto font selected somewhere but I don’t remember where. If I uninstall and then install again the demo, would I lose all of my selections?
If you have a demo installed and you have changed some settings, when you uninstall it the default settings will be loaded and you will lose also your changes. If you don’t want to uninstall the demo, you can only manually change the font. Roboto font is a default theme font used for article title on modules,block title – http://screencast.com/t/ZNq7BpWry – http://screencast.com/t/vLXPJc5O
Alin [tagDiv].
If you export your settings and then import it again you will have the settings that you have right now. Not sure what you will change like this. Like I said above you can only manually change the font. Not sure what you have done in Theme Panel and you cannot revert the font, just set you font to default.
