I was originally designing a web page without a sidebar, but then I changed my mind. Now I want to migrate the blocks that I have in one column over to the sidebar panel. How do I save the blocks’ settings so that I don’t have to completely remake them when I add them to the sidebar?
For example, one block I want to move is the search bar. But I have a bunch of settings changed already to make the search bar look exactly how I want, and I don’t want to go through and have to change every setting all over again.
I also noticed that there doesn’t seem to be a way to design and save a custom template; it looks like I can only choose a pre-made template from online. Is that the case, or is there a way for me to save a custom template?
Thanks in advance,
Samara
You can save the block with the design you made using the right click -> https://i.imgur.com/hvI36Kq.png -> https://i.imgur.com/i2SIqg7.png after that you’ll find the element in composer elements -> https://i.imgur.com/CrySPD5.png
After that drag and drop the element where you want, in pages and cloud templates.
