Hello Bogdan,
If you want to continue using blocks that are in the widgets, then you need to change block 2 with block 4 => https://www.screencast.com/t/of4bU5RffH , or you can add flex block 1 added with tagDiv Composer => https://www.screencast.com/t/M0frT2GZf1LU
Hope this helps you!
