How to set (max_execution_time) and (max_input_vars)?
I’m in trouble with these two entries (max_input_vars = 5000 and max_execution_time = 300), I can´t set them in this numbers, the default options don´t change.
This message in the PHP.ini (Note: This directive is hardcoded to 0 for the CLI SAPI) doesn´t allow to set the entries to the values required.
Does anyone know how to fix it?
Please follow this tutorial: https://forum.tagdiv.com/system-status-parameters-guide/
If for any reason you cannot set up php.ini you have 2 alternatives. One is to add these values in htaccess or contact your host and have him set them up from their side.
