How to set up registration for members and option for them to comment on posts ?
I see in a top of the header a button for Sing in/Join, but when you click it there’s only a login for without option to Sign up…
Hopefully you have an article on how to set up members which can comment on posts.
Thanks in advance!
If you want that your members to can let a comment to your posts, you can set an option to everyone to can let a comment -> https://i.imgur.com/bMOaW5i.png or if you want to get comments only from users that are registered, then you need follow our guide from here -> https://forum.tagdiv.com/newsmag-login-how-to-enable-the-user-registration/
Hope this will help you!
Hi Calin
I am experiencing the same as described above.
Quote – “I see in a top of the header a button for Sing in/Join, but when you click it there’s only a login for without option to Sign up…”
I am using ‘Header template 63’. I can login with my WP account, however when I click login/signup .. on the pop up login window there is no option for signup (login only).
I tried various header template with no luck.
Any assistance would be appreciated.
Please disregard my last post. Wasnt aware of the fact that I had to allow subscribers to join under ‘General’ tab.
Hi rdatta000, I’m glad that you manage the situation.
