How to setting recent post label ?
Hello, i’m using NewsMag. I have a little problem, i don’t know how to change content in widget recent post by label.
For example : Content showing in “FASHION WEEK”, and how to change the name ?
and for the other widget like GADGET WORLD, HOLIDAY RECIPES, BEST Smartphones ? please help me to change it.
i’m confused, i don’t found the solution.
site link : http://www.ceritapadang.com
Please help me
Thank you
Those are blocks, you have to edit the page and open the settings panel for each block. There you can change the block title and the category displayed by each block. – http://screencast.com/t/kMtO6Nw6http://screencast.com/t/AoLCdlNw6c
After you made all the changes just update the page – http://screencast.com/t/LDfOv9iMh
For modules which appear on posts/categories/etc on sidebar, you have to open the widget area and change the settings on each widget – http://screencast.com/t/aOUlf35Df5a
For more details you can also check the documentation – https://forum.tagdiv.com/newsmag-block-settings-tutorial/https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/https://forum.tagdiv.com/newsmag-page-templates/
And the last question, how to change this style http://screencast.com/t/fPA2SVDQUeZ
Solve for the new problem.
this is the new problem, why this picture is not full size : http://screencast.com/t/2a8xeFBK
the picture is large with best resolution. How to fix the problem and make full screen
The original image may be smaller that the thumb size used on this location of the Big Grid.
Check it’s size, the size of the Big Grid thumb is 537x360px. If the image is larger try to regenerate the thumb using the Force Regenerate Thumbnails plugin – https://wordpress.org/plugins/force-regenerate-thumbnails/
If the image is smaller you have to use a plugin which comes with an upscale function, wordpress doesn’t have such an option by default, try this one – https://wordpress.org/plugins/thumbnail-upscale/ – after it’s active regenerate the thumb using the Force Regenerate Thumbnails plugin.
Oke i will try, how to change this popular category http://screencast.com/t/qwTYdkvzEqC ?
and why, my post editor just show half not full sizehttp://screencast.com/t/jOfylBh1F ? how to resolve the problem ?
and the next question, what is the function of Primary Category ? let see the picture. http://screencast.com/t/gylITE5k2
so, i must regenated thumbnail image using the plugin ?
The popular category widget can be edited only by affecting the code from td_block_popular_categories.php file: http://screencast.com/t/HHbJRLePf
The editor was designed to have the same width with the post content on front-end. If your’re using sidebar the post content have 640px, so the editor have the same width. If you’re not using sidebar the post content have 980px and also the editor change width’s changes at this value. Basically the editor simulate the front end layout. You can make the editor full width by removing this code from editor-style.less file: http://screencast.com/t/Vef9ReyLvsC2http://screencast.com/t/Ko7LseFc2fw6
Hope this help.
If i remove the code from editor-style.less, did i will make my theme broken ?
Before making any modifications make sure you do a full backup to the database and your current wp install. This is a safety measure, in case something goes wrong you can always get back to the previous install. However by removing the indicated code the theme’s functionality won’t be affected.
How to make a backup for this theme ?
And the last, how to make auto update for this theme ?
Please check this link for more details about the backup process: https://codex.wordpress.org/WordPress_Backups
You can find all the details about the automatically update process in our documentation at point B: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/http://screencast.com/t/laMpsQ3Wi
