How to setup Review stars in comment?
Hello Team,
How to setup Review stars in comment? when i will setup Flex Box 1 its showing option to display Show review stars. How i can make it working?
Here is screenshot: https://prnt.sc/sfc66k
I look forward to hearing from you asap.
Hello !
At the bottom of your posts you can set reviews, by selecting the star type review the flex block will be able to show your review there: https://www.screencast.com/t/Lu5wBDBAt
Okay Thanks Vlad. Let me check thanks for your quick reply.
