How to show author bio using authors box module
Hello! Is there a way to show the author bio using the authors box element in visual composer?
Using Newspaper v. 3.0.1
Unfortunately the page author box can’t be added via Visual Composer. You can use the Authors box element of Visual Composer but it not the same: http://screencast.com/t/lX0Miqw9
You could also customize the “Authors box” element and add modify it to show the authors bio as you like from here: http://screencast.com/t/99TrqJAp5
You can see how the author box was build here: http://screencast.com/t/6DqWdxNNgp
Unfortunately you will need custom work for this which we cannot offer at this time as we work hard on the development, updates, fixes and support. You can always get a freelancer from sites like: http://studio.envato.com/ if you don’t know how to do it yourself.
