How to show header and footer?
So how to fix it?
Ohh, I got it. Thanks
Do the themes have table content?
Hello @tola999 !
Check this guide: https://forum.tagdiv.com/use-tabbed-content-shortcode/
For posts, we have this shortcode as well: https://prnt.sc/V9l0OHpwddVG
I hope that help you!
Do I have to add table content every time I post?
Hello @tola999 !
If you use a global template for all your posts, then the shortcode will appear on every post.
How to use global template for all my posts?
I have fixed it.
How to add flex box to widgets?
Hello @tola999 !
You do not need to add it there because you can find it in the tagdiv Composer.
You can add any element in the sidebar in the TagDiv Composer. If you add it to a template and make it global, then it will appear on every page that has assgned that template. You can build a sidebar with the TagDiv Composer. Steps:
1. Insert one new row (or delete an existing one).
2. Divide into two columns (2/3 + 1/3).
3. You can add whatever element you want into the second column and consider it a sidebar.
Okay, got it.
I want to import category from cloud library on specific one and not affect other categories.
Can I?
Hello @tola999 !
Of course, yes. Install the category template and assign it only to your special category (without making it global).
Viewing 13 posts - 26 through 38 (of 38 total)
