How to Squeeze Comment section
Hi Team, how to shrink or add load more button or comment button for newspaper theme
Unfortunately, for the moment our theme do not have this option, sorry.]
I added this as a suggestion on our list.
Is there any way to use a shortcode so that it can be done? If the code is not there, is there any way we can call the comment section using a code?
Using the comments from our theme it can be done only f you edit the theme code, for this you’ll need a developer.
Another solution will be to try a comment plugin that have this option, or maybe to vide a js code that can do that.
