How to summarize posts on home page?
Hello there!
I have recently purchased newspaper theme and i don’t know how to show latest posts with featured images with summaries on homepage!
Can anyone help me?
Hello !
You can edit any block in the homepage using the tagDiv Composer and in the filter sections you have multiple options in order to achieve te result you want: https://www.screencast.com/t/BcBfL3YMq7wI
I hope this is helpfull !
Hello there!
I do have that tagDiv Composer but am not able find any options to edit homepage!
I don’t even find any way to use that tagDiv Composer
Can you please help me with the same?
Here is the link of my website!
can you please check?
https://sawingexperts.com/
thanks!
Hello !
In order to have your page editable with tagDiv Composer your will have to edit the website in order to use a single page not the blog option from here: https://www.screencast.com/t/w7WD53F1t1v
You can find out more about it here: https://wordpress.org/support/article/creating-a-static-front-page/
