How to use shortcode of "third parts"?
I sorry to bother,
kindly, somebody could tell me if is possible insert in homep age edited with Tag Div composer shortcodes of third parts?
I want t put in home a calendar shortcode (made with ICS calendar) but I dont understand what kind of widget can I use… I tried with simple text, HTML… no results.
Could you help me please?
You can add the shortcode in the column text or text with title.
“Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
Thank so much… I’ll try again 🙂
thank for your answer and your patence 🙂
best wishes
Alberto
